Hoping to resolve a persistent error I've been receiving when trying to employ raster processes in Python: 010092, Invalid output extent. I'm projecting with Canada Lambert Conformal Conic. I'm fairly confident the syntax is correct; given the fact both the Euclidean Distance and Line Density processes fail with the same input layer, I'm suspicious of the input.
I should add that when I run the Euclidean Distance or Line Density processes directly through ArcGIS Pro the processes (seem to) run using the same dataset called as the input in the script. I haven't run the processes all the way through in ArcGIS Pro to confirm this as it's a national dataset and would take substantial time, but it does (start to) run. Fresh perspectives are appreciated.
