I'm using below code to access FeatureService published using ArcGIS Server. REST endpoint is access protected.
import urllib, httplib
def getToken(username, password, serverName, serverPort):
# Token URL is typically http://server[:port]/arcgis/admin/generateToken
tokenURL = "/arcgis/tokens/generateToken"
# URL-encode the token parameters:-
params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Connect to URL and post parameters
httpConn = httplib.HTTPConnection(serverName, serverPort)
httpConn.request("POST", tokenURL, params, headers)
# Read response
response = httpConn.getresponse()
if (response.status != 200):
httpConn.close()
print "Error while fetch tokens from admin URL. Please check the URL and try again."
return
else:
data = response.read()
httpConn.close()
# Extract the token from it
token = json.loads(data)
return token['token']
if __name__ == '__main__':
token = getToken('<username>','<password>','<host>','6443')
print tokenI get below error:
socket.error: [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
I'm able to access this Feature Service if I put this URL in a browser and enter the username, password.
Am I missing something in the above code?
My Best,
Meghan Kulkarni
