Expose the Statistics for external reporting for Portal usage.
Thank you for submitting your idea!
In order to better understand the enhancement you are looking for regarding external reporting, can you please provide some insight into the workflows you would intend to do, and the use cases which this Idea is asking for?
HI Thomas
Thanks for responding to this enhancement.
If you need further details please let me know.
Currently I use Tableau to audit the ESRI environment.
I run a python script that extracts information into a csv file which is then loaded into a database for consumption by the asset owners to determine usage across the platforms
Below is the Map Service statistics
I have exposed the publishing properties as there were questions around tuning. The below provides a whole view of all map services published and the properties used for each.
I also created a lineage of each map service so that you are able to see what map service is connected to what table via a specific SDE
There are also usage reports I’ve created by capturing and transforming the IIS logs on the web server into usable statistics
Cheers
PETER BIRKSMITH
Senior System Analyst
EO BI D&SE, Information Delivery
IAG
Phone: +61 (0)2 9292 9167
Fax: +61 (0)2 9292 1111
Mobile: +61 (0)424 099 423
Email: peter.birksmith@iag.com.au<mailto:peter.birksmith@iag.com.au>
Assyst Requests: Assyst Requests<https://assystportal.iag.com.au/assystnet>
Address. Lvl22, 388 George St, Sydney NSW 2000
www.iag.com.au<http://www.iag.com.au/>
We help make your world a safer place.
PLEASE CONSIDER THE ENVIRONMENT BEFORE PRINTING THIS EMAIL.
Sign in to post, follow content, and more. New here? Register for free.
