Came here to suggest something similar for Pro. You typically have advance knowledge of the data design for the features you'll eventually populate, and it often behooves you to get your symbology set up ahead of time. While you *could* create dummy data, make the symbology, and then delete it, why not just have an option to add the appropriate domain values for the symbolization fields? For example, both my CDBG Funds and Condition fields have different domains, but to get those into the symbology when they don't yet exist in my data, I have to manually re-type each individual domain value (with no typos and in the right order, too!). Everything is set to 'fair' condition right now, so I have those, but nothing else shows up when I go to add.
Would an 'Add from Domains' option from this menu work? I think that would get the job done.
Or an 'Add all domains' button on this bar.
Oh, and this idea seems similar if not the same: Use Domains for symbology when available - Esri Community
Sign in to post, follow content, and more. New here? Register for free.
