Is it possible to use a choice filter with a regular expression. Ideally storing multiple options in the choice filter column in the choices worksheet like below:
survey worksheet
choices worksheet
Simon Watz this has been previously discussed here:
https://community.esri.com/thread/221635-is-there-a-way-to-create-cascading-selects-without-writing-out-every-possibility
The Survey123 team indicated that expression support is limited, but also posted an example using multiple columns as choice filters.The original poster also provided their workaround solution.
Or could I use a Contains() in the choice filter?
James Tedrick is there any support for using choice filters this way? Where a choice can filter into several options in a list.
I found that adding the items several times (one for each choice filter) worked but wasn't sure if it's a good idea. The only side effect I could see was that the field didn't have domains a usual other select_one question would.
This approach is also a bit clunky for longer lists.
