We have a regular text field with a now() calculation to get the current time in our survey. When we submit survey and we look at the record in portal and ArcMap it's displaying something totally different. How can we display our current time in EST?
Hi Jordan,
Time data is stored as UTC time - it should be 4 or 5 hours off depending on daylight savings (for the Eastern time zone). As mentioned in Setting the time properties on data—Help | ArcGIS Desktop , the time zone can be set as part of the time settings. Convert Time Zone—Help | ArcGIS Desktop can be used to calculate to your local time zone. In version 2.7, we introduced the pulldata("@property", 'utcoffset') function to be able to record the time offset when the data was collected to be able calculate a local time.
Thanks! On the survey123 form the it lists the AM & PM but it doesn't seem to move that to the enterprise geodatabase. If there a code that we need with Now()?
now() should be presenting the current time the survey is taken; that is then stored in UTC time when written to the feature service. For example, if I take a survey at 9:00 am EDT (we're in daylight savings currently), it is 1:00pm (or 13:00) UTC; that is the value I would expect to see when viewing the results in a program that does not automatically assume UTC and adjust for the local time zone (like ArcMap). Are you saying instead that you are seeing a value of 9:00 pm?
Did the OP find a way to change the display? I feel like this is closely related to my question and I am trying to get some answers.
Change military time display in record table
Thanks!
James Tedrick
Jordan Miller
