I've created a MMPK file that uses a VTPK where the most detailed level cached is 1:5000 scale. I've then download to a device and loaded up within Explorer. Will I only ever be able to zoom in on that MMPK to 1:5000 scale or should it be possible to go beyond that scale (not sure if the phrase overzoom is the correct one here but it sort of sounds right) even though I'm not getting any increased detail from the VTPK?
From what I can tell if I have a vector tile service as part of an online/dynamic map I do seem to be able to go beyond the largest scale that it is cached at. So just wondering if the same is theoretically possible with MMPK and if so is this handled in the VTPK creation side of things, the MMPK creation or both?!
Gareth
