Hi Geonet
Do I need to trigger something before I can set up the new webhooks for Survey123 with Microsoft Flow? When I search for Survey123 I get no options. Do anyone have the same issue?
Best regards Niklas
Hi James
It is now available in MS Flow again, so thanks for solving it.
I can see Survey123 trigger in Microsoft Flow from Italy...
Hi Niklas,
We have been informed that the connector has been deployed to all MS Flow regions. Can you please attempt to create a Flow with it again?
I keep having the same issue as Megan, with no Survey123 connector when I search for it under 'add a trigger'. Is there something else that we need to configure to access it?
Hi James,
Below is a screenshot of what I see when searching for the Survey123 connector. Are there any additional steps required to access the connector that are not listed in this set up page: https://community.esri.com/groups/survey123/blog/2018/07/19/automating-workflows-with-survey123-and-microsoft-flow ?
Hi Megan,
The Survey123 connector is available in Microsoft Flow. You should be able to use 'Create from blank', 'Search from hundreds of connectors and triggers' and type in Survey123 and see it in the results:
Hi James, is there an update on when the Survey123 connector will be available in Flow again?
James Tedrick I am also unable to see the Survey123 connector, my region is set to United States.
Yep it is weird. I am using it in Europe.
You should be able to see the Survey123 connector. Just to check, which region are you using Flow in (Regions overview for Microsoft Flow - Microsoft Flow | Microsoft Docs )?
