I have found a feature class (one for now...) that when preview it, this error appears:
Error: The selected object failed to draw discusses the problem when seeing the error in an Oracle eGDB: we use Sql Server. Is the procedure the same? I'm working on a python solution to automate finding and fixing feature class problems (see https://community.esri.com/thread/217423-feature-class-extents-change ). Is there a python method to find this problem?
Neither- we are a Sql Server shop. Something I should add is this particular feature class is within a feature data set, so the exception is more than likely an issue between the source feature class and the feature data set.
Are you working with a standard Oracle SDE geodatabase or a spatially enabled Oracle database that just has SDE ST_geometry libraries installed?
It is weird! I don't get where the 'valid coordinate range' would come from....
weird... it is like a mismatched coordinate system
