Good Morning,
I have created a polygon layer by creating a buffer around a set of points. If I set the symbology as a solid fill, the layer exports to PDF with perfect vector clarity, even zoomed in.
A gradient fill does not have the same result. The same shape exports with a jagged periphery. I initially tried doing a two color gradient, where one of the swatches was the "no fill" swatch. This looked great in ArcGIS Pro, but not on export. I then tried switching the "no fill" swatch to a color thinking it was somehow a transparency issue, but I had the same result.
Is anybody else experiencing issues with gradient fills?
Thank you for your time!
