Hi there,
We have applied a new SSL certificate to our server hosing ArcGIS Server and since then, it's impossible to connect to ArcGIS Server anymore.
Our IT support has trouble shooted the issue and they still try to figure out what's the issue. Here is their input, any clue would be much appreciated.
Thanks.
Last June, we tried to apply a new certificate on the ArcGIS server. The latter did not apply correctly. So I deleted them and requested a new valid certificate. However, when I bound the certificate in IIS, ArcGIS stopped working.
I can no longer access the "AcrGis Server Manager" web page by https://ourserver:6443/arcgis/manager/
IE tell me that the web page is not available.
The Microsoft Security patches of June have been applied in a same time.
It seems to be a problem between IIS and ArcGIS.
- I tried to unbound the certificate, same issue
- I tried to reboot the server, same issue.
- I uninstalled the Microsoft Security patches, same issue
- I tried to re-bind the last certificate, same issue.
The only way to bring back the application functional is the reinstallation of IIS.
But as soon as I reboot the server, ArcGIS stop working again, same issue.
I need your help to understand the reason why ArcGIS stop working.
I would like to understand how ArcGIS is called through https://ouserver:6443/arcgis/manager/
Have you ever seen this kind of issue?
