I just installed arcgis server desktop 10.0 and also arcgis server 10.0 and when I type http: // localhost: 6080/ARCGis/manager it does not work ... but when I type localhost:80/arcgis/rest it works.
Please help me.
At 10.0, you reach Server Manager through ports 80 and 443. Starting at 10.1, you'll reach Manager through 6080 and 6443.
I have already tried these ports but it does not work
As mentioned by JQuinn-esristaff, port 6080 and 6443 are only applicable for ArcGIS Server 10.1 or later.
Since you are working on ArcGIS Server 10.0, you need to login to manager through http://localhost/arcgis/manager or http://localhost:80/arcgis/manager
instead of localhost, try can also the machine name or the IP address. I know on our machines, localhost didn't always work, although I don't recall the error (we're on 10.2.1). ...and keep in mind, localhost would only work when on the ArcGIS Server server itself, not from a separate machine.
it dosen't work too but with the rest http://localhost:80/arcgis/rest or http://localhost/arcgis/rest it's work
it dosen"t work too i'm overtaken
You'll have to describe what doesn't work means. By default, I don't think SSL is enabled at 10.0, so I think you should focus on http. If you navigate to http://localhost/arcgis/manager or http://<machine_name>/arcgis/manager what do you get? Are you unable to connect at all, (unlikely as you can get to REST)? Is it an authentication issue? If so, are you logged in with a user that's part of the agsadmin group? Finally, 10.0 is deprecated and has been for some time. If you're getting started with ArcGIS Server you should be working with a more current version.
Mr for rest http: // localhost / arcgis / rest it works but for the manager when I type http: // localhost / arcgis / manager or http: // localhost: 80 / arcgis / manager or http: // localhost: 6080 / Arcgis / manager it does not work (an error page) I have ISS activated also HTTP the problem is that I only have this version of arcgis server 10.0
Try to open the ArcGIS Manager from the following
Start > All Programs > ArcGIS > ArcGIS Server for the Microsoft .NET Framework > ArcGIS Server Manager
I am on windows 10 I can't do the same step but I did and nothing new always a page of error that opens
Did you check the supported operating systems before installing ArcGIS Server 10 on a Windows 10?
You might need to downgrade your OS to Windows 7 SP1 or upgrade your ArcGIS Server to 10.3.1 or later.
Supported Operating Systems
Minimum Version
Maximum Version
Windows 2003 Server Standard, Enterprise & Datacenter (32-bit and 64-bit (EM64T))
SP2
Windows 2003 Server Terminal Services
Windows 2008 Server Standard, Enterprise & Datacenter (32-bit and 64-bit (EM64T))
Windows 2008 R2 Server Standard, Enterprise & Datacenter (64-bit (EM64T))
SP1*
Windows 7 Ultimate, Enterprise, Professional, Home Premium (32-bit and 64-bit (EM64T))
Windows Vista Ultimate, Enterprise, Business, Home Premium (32-bit and 64-bit (EM64T))
SP1
Windows XP Professional Edition, Home Edition (32-bit)
SP3
Windows XP Professional Edition, Home Edition (64-bit (EM64T))
Could you please use teamviewer to help me i ll give you access to my laptop
this is my mail : safiri.abdelwajid.1@gmail.com
Hi Abdelwajid,
Trying to install and enable ArcGIS Server 10 (which is no longer supported) on Windows 10 OS isn't really practical. The software was not designed and not meant to work with this OS release. And it's likely that the OS has different and/or upgraded internal components that ArcGIS Server 10 won't understand.
I recommend you get a more recent release of ArcGIS Server to use.
Hope this helps,
Hello Derek,I tried to install this version on windows 7 and 8 but still the same problem.Please do you have a full version of arcgis server 10.3 or 10.2 ?
You shold be able to download the install files from https://my.esri.com assuming you are/were on maintenance when they were released. Downloading and installing will not help unless you can authorize the software.
Please contact your local Esri account manager/Distributor to get the latest version of the ArcGIS software.
Contact Us | Esri About
