When publishing from desktop to server, I am seeing the following SEVERE errors in ArcGIS Server Manager:
Method failed. HRESULT = 0x80070057 : The parameter is incorrect.
Followed by:
Failed to rename cache folder.
These are map services, set to dynamic (no caching) in the caching tab, so the question is where and what is the cache folder it is referring to? I've looked at this error elsewhere and it definitely claims to be a permissions issue, but all of the folders it suggests ensuring have the correct permissions do so. In addition, the cache folder specified in the directories on the Site page, is this just for actual caches or all? Every time I look at the documentation around this all it talks about is generation of tile caches, which is not what these services are supposed to be doing, so what cache folder is it referring to?
TIA
Dan
