I have a shapefile with a field I am using for labels. The attributes in this field are long company names. I will be publishing the contents of this map to ArcGIS Portal as a map service too, so I want to clean up my labels.First, I'd like to stack the labels.Second, I would like to truncate them by replacing common words in all these company names (eg. replace Company with "Co.", Beverage with "Bev.", Distributing with "Dist.", and so on...)Is there a single script where I can accomplish both?Thanks!
Function FindLabel([COMPANY_NAMES]) Dim MyArray, i, names MyArray = Split([COMPANY_NAMES], ",") For i = 0 to UBound(MyArray) If i = 0 Then names = MyArray(i) ' Begin a single company. Else names = names & vbCrLf & MyArray(i) ' Insert a new line after every company name. End If Next Replace(names, "Limited Liability Company", "LLC") Replace(names, "Company", "Co") Replace(names, "Beverage", "Bev") Replace(names, "Distributed", "Dist") FindLabel = names End Function
Hi rfairhur24 - thanks for the post reply.I tried to copy and paste the code into the expression window under the Labels tab, but I get an error message:"The expression contains an error.... Error 8 on line 35. Cannot use parentheses when calling a Sub."Also, just to be clear, the field I'm using for the labels looks something like this:[ATTACH=CONFIG]26782[/ATTACH]Thanks so much for your input!
Function FindLabel([dist_name]) Dim name If IsNull([dist_name]) Then name = "" Else ' Add as many replace expressions as you need. ' The first string in the pair must match your input exactly to be replaced. ' The order of replace statements matters. ' Words that can be part of other replaced words must come last. name = [dist_name] name = Replace(name, "Limited Liability Company", "LLC") name = Replace(name, "Company", "Co") name = Replace(name, "Beverage", "Bev") name = Replace(name, "Distributed", "Dist") End if FindLabel = name End Function
Edit: I found the error in my code. I have to assign the replace output back to the name variable as shown below. Normally I use this in the Field Calculator and don't have to do that step, but it is required in a label expression.Just for the sake of trying it, use this code. It will do nothing to stack your labels, but it should do the word replacements without error:Function FindLabel([dist_name]) Dim name If IsNull([dist_name]) Then name = "" Else ' Add as many replace expressions as you need. ' The first string in the pair must match your input exactly to be replaced. ' The order of replace statements matters. ' Words that can be part of other replaced words must come last. name = [dist_name] name = Replace(name, "Limited Liability Company", "LLC") name = Replace(name, "Company", "Co") name = Replace(name, "Beverage", "Bev") name = Replace(name, "Distributed", "Dist") End if FindLabel = name End FunctionIf you did the edits to the fields with the field calculator you would use the Replace expression anyway, i.e.:Replace([dist_name], "Company", "Co")So that statement will work unless there is something very strange in your field that I have never encountered before (none of the characters you mentioned would be special or trigger an error).The only character that would throw an error in your company names that I know of is a double quote ("). Do you have that character in any actual company name?
--------------rfairhur24,Thanks so much for your earlier help. This script has been working great! Just curious if there's a way to update it so it stacks my lllabels after the first word. For instance, if the company name is "Pacific Beverage Company", the script would still replace "Company" with "Co.", but stack the label where Beverage Company comes as a single line under Pacific. Thanks for your help,tiamo
Function FindLabel([dist_name]) Dim name If IsNull([dist_name]) Then name = "" Else ' Add as many replace expressions as you need. ' The first string in the pair must match your input exactly to be replaced. ' The order of replace statements matters. ' Words that can be part of other replaced words must come last. name = [dist_name] name = Replace(name, " ", vbNewLine, 1, 1) name = Replace(name, "Limited Liability Company", "LLC") name = Replace(name, "Company", "Co") name = Replace(name, "Beverage", "Bev") name = Replace(name, "Distributed", "Dist") End if FindLabel = name End Function
