Did anyone get past the new schema not visible in the post install drop-down?
Nishi Mishra Any suggestions for the missing schema...only SDE is visible.
Follow-up...Still having the issue about schemas not available in the WMX Post-installation.
Hi,This is Vivek from India, I need your help, I am a new user to WorkFlow Manger and trying for the installation of ArcGIS WorkFlow Manager 10.1, I am also following esri 10.1 best practices whitepaper. My DB has completed Step1 & Step2 , I exported dbtune file and now I am not able to understand which tablespace name do I need to change with for the appropriate parameters. If you can help me that will be a gr8 help. My Database configuration is as following. Only one master SDE repository geodatabase was createdThe default data type is ST_GeometryThe spatial data within GIS_CVE of ORADV131 have been copied to GIS_CVE in ORADV141Default tablespace for spatial data is CVE_VECTOR, CVE_INDEXConfiguration keyword SRC is created to load spatial data to GIS_SRC and table spaces (SRC_VECTOR, SRC_INDEX)I am not able to make a decision whether ##Default or ##SRC parameter, I have to choose for configuring ##WMX Parameter, In the configure file there are certain parameters, example XML_IDX_INDEX_TAG, for this parameter which tablespace do I choose ?For your reference, have attached my dbtune_exp.sde file, request you to kindly have a look and suggest.Kind RegardsVivekvivekk.gaikwad@gmail.com
Created a new GDB in Oracle 11R2. New user WMX was created following best practices whitepaper.Import desired dbtune keyword "WMX"Running postinstallation the only schema available in the drop-down list for the database connection is SDE (do not see other schema as expected, in this case "WMX").If using SDE schema, which is not desired, cannot see the new keyword created in the drop-down list in the "Configuration Keyword" window. Why this behavior???? What am I missing???
