I joined a CSV file to a feature class. And when I performed Calculate Field, the PRO crashed.
Any help?
La Ode Abdul Hafid - in reviewing this question, is the data you're working on from the Getting to Know ArcGIS Pro from EsriPress? The screenshot looks like data from a lesson there based upon a support incident I'm seeing. If so, it is a BUG referenced below:
[#BUG-000104025 : Pro crashes when trying to Calculate Field on a new field in a joined table with data from the Getting to Know ArcGIS Pro EsriPress book.] The workaround for this issue is to modify the CSV file using the following workflow:1. Open the referenced household_income.csv file.2. Locate and modify the record containing the HHINCOME value of “2,500-” to read “2500” instead.3. Clear the contents of the HHINCOME field for those records containing dashes.4. Alter the “GEO.id”, “GEO.display-label”, “GEO.id2” column headers to remove the special characters.6. Save the CSV file and step through the workflow again. No crash will be encountered.
I find it helps that after a join, I export the joined data to a new feature class. Then I can perform field calculations and such. If I work on joined data without exporting it, I oftentimes run into problems. Maybe you should try exporting the joined data, then do field calculations.
But can't the workflow (join table - calculate field - unjoin table) be performed, since I found this issue in ArcMap too and the solution is the same?
Look at the documentation: Fundamentals of field calculations—ArcGIS Pro | ArcGIS Desktop
It is hard to tell by the screenshot, but you are trying to calculate a field in the CSV, correct? If so, that is not supported.
The field belongs to a table that has been joined to your table. You can only calculate values for fields in the origin table.
Even if what he is trying to do isn't supported, which I don't think it is, the application shouldn't crash. This is a bug if it is reproducible.
I am trying to calculate a field in feature class not CSV file..
hafidloa Can you please message me so that we can get your crash dump?
Thanks. Anyone has ever been successful perform the join-calculate
field-unjoin workflow in PRO if I may know?
Yes. It works. Thank you.
Yes it is true. Currently I am studying the book Getting to Know ArcGIS Pro from EsriPress.
Thanks all for responding to help hafidloa As rleclair-esristaff correctly pointed out, a bug was logged with support and testing indicates that the crash doesn't occur with Pro 2.0 which is coming very soon. Look for 2.0 and as always stay on the most up-to-date release.
