I have created a map service using ArcGIS/ArcMap (10.4.1). I can prepare it for caching, but the last one took almost 5-days to run, so this time I am hoping to do it entirely in ArcGIS Pro instead. I would like to cache this image and then use it in Portal. I have already done smaller ones...this one is slightly larger. The process usually does work well.
I have created a link to ArcGIS for Server in ArcGIS Pro, but now when I try to add the map service that I would like to cache (using the Manage Map Server Cache Tiles tool) I get an error (000732: Dataset does not exist or is not supported). I can still add the same map service using the exact same tool in ArcGIS though.
Is there a trick to this that I'm not quite grasping? Perhaps I need to use a slightly different path? Has anyone else managed to use ArcGIS Pro to cache an image for use in Portal?
