Hello, I encountered a problem while trying to use the adjust tool in ArcGIS Pro. I intended generating an orthomosaic from the drone images I had, however, after creating the workspace successfully, it would show an error 999999 during the block adjustment and indicate that something unexpected caused the tool to fail. I've tried a few solutions from the ArcGIS Pro help but it still displays the same thing. Pls help, what could be the missing handling tool and how do I go about it? Thank you
esrisupport arcgis, Esri Technical Support
