After processing the imagery is "fuzzy" and not as sharp as the raw imagery.
I have adjusted the processing parameters but have not had much improvement in the processed image quality.
Bill
screen grabs?
can you show what and where you made adjustments?
Are you processing using the Rapid or 2D Project Template? The Rapid Project Template will produce products with a lower resolution, it is designed to do quick low resolution processing.
Dan,
I used the default 2d template (not rapid). I have played around with the 2d options, Resolution, Merge tiles, Big TIFF.
