This was a discussion about ArcGIS for Windows Mobile, and this is a complete different product than ArcPad.
So maybe you will be more succeeded in the right community.
I am having partial success with using feature class attachments for photos in ArcPad 10.2 with a Trimble Geo 7X and it's built in camera. I have to access the attachment table in ArcCatalog and insert "RASTER" as the Default CONTENT_TYPE field and insert a value e.g. 15 as the Default DATA_SIZE field. I check the data out via Trimble Positions tools and move to device. Open ArcPad on device, start editing on the feature class with attachment, select a feature and open the Feature Properties window, click on the feature Attachment tab, add attachment record, click on the camera button in this window, take picture, save edits exit ArcPad, check data back into the geodatabase via Trimble Positions, in ArcMap, use the Identify button and click on the feature which I create an attachment record for in ArcMap, it is now listed but not accessible. It is like the image never gets imported into the geodatabase as an attachment.
If you don't put the Default values in as described, ArcPad will error out when taking the picture on the device. Any ideas on how to make this process work? Thanks.
I�??d like to know is there any way we can load the jpg file to the Raster field in a feature class programmatically by using SQL script or .NET or the SDK...
using ESRI.ArcGIS.esriSystem; using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS; using ESRI.ArcGIS.Carto; ... public byte[] GetRasterFieldAsJpg(int objectID, string featureClassName, string rasterFieldName) { #region ArcObjects License Initialization... RuntimeManager.Bind(ProductCode.Server); //** Check server license IAoInitialize aoInitialize = new AoInitializeClass(); if (aoInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeArcServer) != esriLicenseStatus.esriLicenseCheckedOut) return null; //** License error #endregion #region Open the workspace and the feature class... // Create the workspace factory and instantiate the workspace. IPropertySet propertySet = new PropertySetClass(); propertySet.SetProperty("SERVER", "192.168.1.1"); //** DataBase server propertySet.SetProperty("INSTANCE", "sde:oracle11g:DBName"); propertySet.SetProperty("DATABASE", "DBName"); propertySet.SetProperty("USER", "username"); propertySet.SetProperty("PASSWORD", "password"); propertySet.SetProperty("VERSION", "SDE.DEFAULT"); Type workspaceFactoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory"); IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(workspaceFactoryType); IWorkspace workspace = workspaceFactory.Open(propertySet, 0); // Use the IFeatureWorkspace interface to open the workspace's feature class. IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace; IFeatureClass featureClass = featureWorkspace.OpenFeatureClass("SchemaName." + featureClassName); #endregion #region Get the raster field as a JPG IFeature feature = featureClass.GetFeature(objectID); if (feature != null) { IRasterValue rasterValue = feature.get_Value(featureClass.FindField(rasterFieldName)) as IRasterValue; if (rasterValue == null) return null; IRaster raster = ((IRasterValue)feature.get_Value(featureClass.FindField(rasterFieldName))).Raster as IRaster; IRasterExporter rasterExporter = new RasterExporter(); return rasterExporter.ExportToBytes(raster, "JPG"); } return null; #endregion }
At 10, you can customize flex viewer to show photos taken with Windows Mobile application that are stored in raster field. If you need sample code feel free to let me know.
So, until ArcGIS 10.1, what is ESRI's recomandation for viewing in a web application (developed in Flex/Silverlight/Javascript API) photos uploaded in the field using an ArcGIS Mobile application?
Hi Akhil,Finding a developer summit video where someone mentions halfway through the video that you do photo streaming either via raster field or blob field with "picture_<fieldname>" is not documentation, it's garbage. Seriously, I'm supposed to "guess" that if I name a blob field "picture_<fieldname>" the app will automagically know it's a picture!???
Here's another link that gives instructions just like I have explained already.http://resources.arcgis.com/content/kbase?fa=articleShow&d=30796
It pretty simple, and it is somewhere in the Mobile 10 documentation on how to do this, as well as Field Crew Tracking.How to add Photo for Data Collection Mobile 10:1) Import shapefile into your SDE geodatabase (using import)2) Click on Preview, then change the dropdown to Table view (so that you see the table, not the geometry)3) Click on Table Options icon > Add Field > Give a Name like "Photo" > the data type will be "Raster"4) Click ok and your done > make sure you add Global IDs and Version your feature class5) Continue to create the Mobile Project in MPC and then test your project in ArcGIS Mobile 10 (Tablet), and in the Photo field you will have the option to browse for an Image and attach it.If you have any further questions please let me know.
