Updated to 2.3 unable to save new polygons while digitizing. No error code just message informing me it does not work.
Hi Liam,
Thank you,
Scott
Good afternoon Scott,
Thank you for replying to my post. The data is being sourced from a geodatabase and it is not project specific. Under the Status tool, it indicates features are editable. I have also noticed that the same applies to adding lines and points, as well as it is not an issue when adding polygons to an existing shapefile, it saves just fine. Feature classes seem to be the issue. I have not done anything different then I would while creating and editing with version 2.2.
Liam
https://community.esri.com/thread/227796-cannot-edit-since-upgrade-to-23 Should cure it....
I saw that post and thought the same thing and checked to see if it was selected (it was not) it just does not want to save edits within the feature class (making new attributes).
Thanks for the reply, Liam. That is definitely odd behavior. A few more questions:
If we can't get to the bottom of it here in a decent time frame, please call Esri Technical Support at 888-377-4575.
-Scott
Hi Scott,
I tried editing a feature from another geodatabase and it seems to work just fine. I don't know why but it seems that my working geodatabase is corrupt, it was fine until the update. I made a new geodatabase and it seems to work fine.
Thank you for your help.
Just for fun, see if you can make the same edits to the offending gdb with ArcMap.
I also have this problem. I cannot edit any feature classes. I even created a new one, then tried to edit and it doesn't stick. Whether you try to move a feature, edit vertices, etc. It just reverts back to the original shape/location after clicking on "finish". Seems like a major bug. I didn't have this problem at all before installing 2.3
I'll mention the same thing I said to Liam: Please open a case with Esri Technical Support. The phone number is 888-377-4575. Please let me know once you have an open case, or if you hit any roadblocks.
Liam didn't see the issue in another File Geodatabase. Do you see the same problem in different or newly created File Geodatabase?
I did not have the same problem when I created a new/empty file geodatabase
so I think it is the same as Liam. I was also able to edit another feature
class (points anyway) from one of my preexisting databases.
Ok so that's good. We'd still like to get to the bottom of it. It's probably best if we work through a Support case, but here are the type of questions I would ask:
Thanks for any further insight.
