How can i zoomin to a map , by drawing a rectangle on the map and zoom that particular area?? Please Help Michael BranscombAntti KajanusMorten Nielsen
Thanks in advance,
Vijit
By default, you can hold "Shift" key and then draw a rectangle on the MapView to use similar navigation. If you want to zoom out, you can do "Shift+ Ctrl" combo instead.
If you want to implement your own, then you can do something like this:
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">Button_Click</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">object</SPAN> sender<SPAN class="punctuation token">,</SPAN> RoutedEventArgs e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// use the MapView's Editor to request geometry (Envelope) from the user and await the result</SPAN> <SPAN class="keyword token">var</SPAN> newExtent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> myMapView<SPAN class="punctuation token">.</SPAN>SketchEditor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">StartAsync</SPAN><SPAN class="punctuation token">(</SPAN>Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime<SPAN class="punctuation token">.</SPAN>UI<SPAN class="punctuation token">.</SPAN>SketchCreationMode<SPAN class="punctuation token">.</SPAN>Rectangle<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// set the map view extent with the Envelope</SPAN> <SPAN class="keyword token">await</SPAN> myMapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SetViewpointGeometryAsync</SPAN><SPAN class="punctuation token">(</SPAN>newExtent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">TaskCanceledException</SPAN> tce<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// sketching cancelled </SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> ex<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thankyou Sir.
