[ASK]
Why domConstruct isnot found?it's look like dojo didnot load.please help.Thank you
Tras,
You made a basic mistake most new AMD style coding develop make. Your require vars do not match your require list.
You have:
<SPAN class="token function">reguire</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyParameters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Popup"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-construct"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> IdentifyParameter<SPAN class="punctuation token">,</SPAN> IdentifyTask<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN>Popup<SPAN class="punctuation token">,</SPAN>Color<SPAN class="punctuation token">,</SPAN> InfoTemplate<SPAN class="punctuation token">,</SPAN> Popup<SPAN class="punctuation token">,</SPAN> arrayUtils<SPAN class="punctuation token">,</SPAN> domConstruct<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
In there you have popup twice and InfoTemplate and popup switched:
It should be:
<SPAN class="token function">reguire</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyParameters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/IdentifyTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Popup"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-construct"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> IdentifyParameter<SPAN class="punctuation token">,</SPAN> IdentifyTask<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> InfoTemplate<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> Popup<SPAN class="punctuation token">,</SPAN> arrayUtils<SPAN class="punctuation token">,</SPAN> domConstruct<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Notice that alignment of the require for "esri/InfoTemplate", and its matching var InfoTemplate have to appear in the exact order that the require list has them in.
The abc’s of AMD | ArcGIS Blog
Thank's very much Robert Scheitlin, GISP.it's helpfull
This might help you: https://community.esri.com/docs/DOC-7801
