I am seeing issues with the performance in Portal Web Maps or Apps when the referenced service uses versioned data. I am not sure if there is a setup or configuration that I am missing.
If I add a Feature Service to a Web Map that is created from referenced data to a versioned database a few things are observed.
- The layer will often not draw completely and the "Layer did not draw completely" message is displayed
- The occurrence of this can be changed by modifying the "Maximum Number of Records Returned by Server" setting
- The drawing is horrendously slow at times.
- During a redraw the ArcGIS Service will begin to spawn numerous instances. I have seen it have as many as 16 running (the max at the time)
- This is a single WebMap being redrawn which will create this number of instances.
When I use a feature classes from an enterprise database that are not versioned (e.g., archive enabled non-versioned data) or use hosted data things work much more as one would expect. None of the items above present themselves (I still think the draw performance could be better, though).
Does anyone know why I am seeing this behavior?
-Joe
