Greetings,
I am hoping to be able to edit an external table through a relate in a javascript application. The relate works fine through a map service, but I can't publish a feature service. When attempting to publish a feature service I get the following errors:
00135 Standalone table's data source is not supported(Feature Service)
00062 Data frame contains data that does not use the sane connection to an enterprise geodatabase(Feature Service)
Is there a work around that will allow me to edit these tables in their current format?(The tables are part of a billing software and I can't let it change formats)
thanks
