Terry,
An alternative to a direct connect syntax to register a database is to use Easy Connect syntax which uses easy connect drivers in Oracle to connect to the database.
http://www.oracle.com/technetwork/database/enterprise-edition/oraclenetservices-neteasyconnect-133058.pdf
Below are the steps that you may carry out to register an Oracle database using an easy connect syntax :
1) Set “path” in the system variables in environment variable beginning from 64 bit client.
(e.g.- \app\NiteshJa\product\11.2.0\dbhome_1\bin;D:\app\Oracle_Client\bin;).
\app\NiteshJa\product\11.2.0\dbhome_1\bin – 64 bit client path.
\app\Oracle_Client\bin - 32 bit client path.
2) Now from Arc Catalog use easy connect syntax to connect to the geodatabase and provide in instance name.
easy connect syntax is "server_machine_name/database_name"
3) Once connected from Arc Catalog, go to Manager page >> Site >> Data Store >>Register Database and provide the sde connection file.
For easy connect syntax, you should have an entry of “EZCONNECT” in NAMES.DIRECTORY_PATH in Oracle Client sqlnet file. The path for sqlnet file is “D:\app\Oracle_Client\network\admin”.
Example for sqlnet file :
Regards,
Nitesh J.
