When i try to add an item or delete an item , i am getting the error "
Please suggest the solution
You may try the following steps to rebuild the index.
1. Stop Portal for ArcGIS Service.
2. Navigate to C:\arcgisportal\index\nodes\0\indices (depending on your portal folder)
3. Delete all the folders in indices
4. Navigate to C:\Program Files\ArcGIS\Portal\framework\template\empty_index.zip (depends on your installation folder)
5. Extract the folders into C:\arcgisportal\index\nodes\0\indices
6. Start Portal for ArcGIS.
7. Navigate to https://<fqdn>/<webadaptorname>/portaladmin/system/indexer/reindex
8. Perform a full reindex.
I followed the steps above to resolve mine. Hope it helps.
For ArcGIS Enterprise 10.7 product: portal
Error: The index service seems to be unavailable. Please check the index service
The Index Service has a safety feature that puts your index in read only mode if you have less then 10% disk space left.
Errors include can't add users cant change password cant delete users etc.
Resolution
Please check the log file to confirm that this is your problem.
C:/Program Files/ArcGIS/Portal/framework/runtime/ds/usr/logs/[Your Server Name]/elasticlog
It this is the problem make more space on the hard drive.
I have a call logged with Esri.inc to find out if we can change the % to a fixed size because if you use a 1Tb disk then you need 100GB of free space all times.
Hope this helps
That check is imposed by the third party component we use for the index. We've removed the disk space check at 10.7.1. At 10.7, there are ways to turn it off as well, but work through Support for that information.
Hi Jonathan,
I am experiencing the index service not available issue after storage out of space (10.7). Note that adding extra space (200GB) again did not solve the problem!
May be the index is still in the read-only mode being I am unable to share or delete an item. The index status is mismatching also. I tried to edit somewhere in elasticsearch.yml but no place talking about threshold or enable read/write mode.
Please advise.
The indices don't automatically turn themselves to read/write if you clear up disk space. Either rebuild it using the steps in the first comment or reach out to Tech Support so you can walk through the steps with them.
I Uninstalled the portal and install it again
I had another broken index in 10.7.1, Szu Nyiap Tang steps resolved it. A easy way to see if the index is broken is if you Reindex does the status go to 0 if not the index is probably broken.
At 10.7.1, we updated how we reindex which should resolve index related problems, (corruption, mostly). If there's a couple item difference between the store count and index count, reindexing won't fix that. The best course of action is to work with Support to identify which items it can't add to the index.
I got the same error message when I tried to add an item in Portal for ArcGIS 10.7, in Linux OS.
"The index service seems to be unavaliable. Please check the index service."
The solutions above seem to fix the problems on Windows. Is there any solution for Linux OS?
While working in Portal 11.2, I didn't see the empty_index.zip file inside the templates. Has anything changed?
