We use quick capture for windshield damage assessments. It is used to determine the location of damage so assessment teams know where to go. Once those are completed how do I clear that data from the map in preparation for the next event?
To add to Johnathans response:
Paul Doherty may have some ore advice on how to do this.
Hi Bryan
I'm assuming that you are using the default basemap with no operational layers in it.
If so, the data is cleared from the map once it is sent to the server. i.e. once sent it is no longer on the device.
The data is either sent automatically at a fixed interval (if auto-send is enabled) or manually from the map.
If the project is configured to use a web map that contains the same layers referenced project, then you will see the submitted data. If you wanted to clear this you would need to view the service items in ArcGIS online and delete the captured records. A better approach would be to apply a filter to the layer so that it only shows records for a certain date range.
John
