It's been a few months since I worked with arcServer, but I seem to rember there being an option on the map service to allow or not allow the user to store a local cache. But I'm not sure if that was an option for dynamic map service or only for cached map services. Good Luck,Tom
Are you sure the data store(s) are registered with ArcGIS Server? I ran into a similar issue where my map service wasn't updating dynamically with edits to feature classes I was making. Turned out that when I initially published the service to Server, the data store(s) weren't registered with Server so it was copying all of the feature classes, images and mxd to a local directory on the server itself. In order to clear that local copy, I had to delete the service, register the data store locations with Server and republish. Once Server knew the communication link between the service and data, the map service became dynamic.
