We constantly get the attached errors in the logs of our Arcgis Server server.
Do you have any idea about this?
Hi @Muhammet_İkbalYaşar,
Is ArcGIS Server behaving normally otherwise? If not, what behaviors do you see around the time these log messages are generated?
This is a fairly uninformative error, so unless there are functional problems it might be hard to pin down the root cause.
Please check the below log errors after two times of 9001 error code 9002 log is registered multiple times please suggest.
Got this same message today, and we are using Geocortex Essentials, the problem is that when using Geocortex to gcreate new features nothing happens and this message remains in arcgis server. How to fix the issue?
We are also getting a ton of these on 10.9.1 with no apparent changes to anything....anyone have any luck figuring out how to fix these? Or are they truly meaningless? Everything is working, I only worry because our logs are full of 'SEVERE' errors, which is hard to simply ignore.
