when importing open source data from get map data the finish button is grayed out
how do I finish importing data when I cannot click finish?
When the finish button is deactivated usually ther is a wrong or missing input. Is there any error or hint shown on the first page the greyed out finish button appears? The hint is usually shown below the tiltle of the dialog.
Check here a similar problem - https://community.esri.com/thread/189486-get-map-data-ok-box-greyed-out
Are you using a local coordinate system or another one?
Esri CityEngine 2018.0.3929 (Build Date: 180503, release, win32-64bit)
experiencing a similar issue when trying to import my own network shape-file. Going through the import tool that lets me use simplify streets the finish button is grayed out but if i just drag and drop the .shp into the 3d view it loads up fine
Are you using CE 2017.1? Or which one?
Did you see the Upgrade Patch?
The CityEngine Team has just issued a patch to fully restore the Open Street Map functionality:CityEngine Get Map Data for Open Street Map Patch Released
