Level Time Message Source SEVERE 2013 5 13 19:22:20 Failed to login, invalid username or password. Admin SEVERE 2013 5 13 19:19:40 Failed to login, invalid username or password. Admin SEVERE 2013 5 13 19:18:35 Failed to login, invalid username or password. Admin SEVERE 2013 5 13 19:14:36 Failed to login, invalid username or password. Admin SEVERE 2013 5 13 19:12:26 Failed to login, invalid username or password. Admin
There is a bug that may apply:See the following Active Directory domain policy:http://technet.microsoft.com/en-us/library/cc778124(v=WS.10).aspxSet "Domain controller: LDAP server signing requirements" to: "None"
The client needs to import a certificate that the client will trust so that the client can validate the tree CA that the LDAP server claims to be using. The client must import a certificate from the server so that whenever the server sends its certificate, the client can validate it and verify that the server is who it claims to be.So that the client can get a secure connection, the client must be configured before the connection.The way that the client imports the certificate differs, based on the kind of application being used. Each application must have a method to import a certificate. Netscape browser has one way, IE has another way, and ICE has a third way. These are three different LDAP clients. Each client has its method for locating the certificates that it trusts.
ToomasAas,Did you ever find a solution to this issue? I've had this happen four times on three different servers (ArcGIS Server 10.2). At some point, ArcGIS Server stops recognizing the active directory and only the Primary Site admin can log in. I've had this happen on a server with GIS tier authentication, SSL enabled and using a trusted certificate. I've also had it happen on a server without SSL enabled, no trusted cert and using WEB tier authentication. The one thing that was common across the servers is that ArcGIS Server was using Windows Domain for authentication. My solution...that sometimes works, is to remove the arcgis-logsettings.json.rlock file and reset the security configuration. If that doesn't work, I restart the ArcGIS Server Service. If that doesn't work, I restart the server. That one has always worked so far. I couldn't find anything in the ArcGIS Server logs or the server manager logs that indicates what had happened to cause this. I'd be happy to hear how you solved this issue.
