WAITFailed to cache extent: 782923.307292 1389101.085069 790032.248264 1396210.026042 at scale 250 ;Failed. Field is not editable. The index was either too large or too small. Failed to execute (Manage Map Cache Tiles). Failed. Failed to execute (ManageMapServerCacheTiles).
Error executing tool.: Failed to cache extent: 153555,381636 6369419,262764 157889,000720 6373752,881847 at scale 500 The index was either too large or too small. Failed to execute (Manage Map Cache Tiles).
I'm picking up this old unanswered thread since I have almost the same problem.I'm getting this error:Error executing tool.: Failed to cache extent: 153555,381636 6369419,262764 157889,000720 6373752,881847 at scale 500 The index was either too large or too small. Failed to execute (Manage Map Cache Tiles).I'm also using a shapefile for cache extent that worked before.
I had this error last week and I realized that for one of the layers in the service, I had added global IDs a few weeks ago so there was a change in the schema.. I tried deleting the cache and that failed.. then I tried resharing the service, overwriting the existing and that failed... then I deleted the service and its cache, and reshared the MXD. then the cache ran successfully. has there been any even minor change in the schema of any of your datasets?
