Dear all,
just wanted to test the Tapped Viewer app, so I downloaded the code and put it on my test server. However, nothing happens, it just loads, and loads, and loads ... : http://speck.conabio.gob.mx/manglarfotos/ejemplo4/index.html
any hints,
Flo
Sorry I was expecting your issue was due to an invalid download but it's not that's an issue with the template, if you remove index.html in the URL it will work
http://speck.conabio.gob.mx/manglarfotos/text-and-legend-map-storytelling-template-js-master/text-and-legend-map-storyte…
pretty bad but the new template will fix that
Hello Flo,
Did you add any of your data to the app?
Hi Amanda,
initially I used the ids that come along with the template, as indicated on github. Following your hint I put some of my own map-ids, but nothing changes - it just loads, and loads, and loads ... : http://speck.conabio.gob.mx/manglarfotos/ejemplo4/index.html
Let me see if I can tag a couple of experts on configuring the apps and hosting.
Gregory L'Azou and Rupert Essinger - They helped me immensely when I was configuring my app. Also Timothy Hales
I'm not sure what happened with your configuration but if I download the templatefrom GitHub http://bit.ly/1eMMQQH and reapply your configuration from index.html (just copy the line 41 to 79 that declare the defaults variable) it works for me.
But you may want to hold on that app, we are releasing tomorrow night in ArcGIS Online a new application that will let you build a Tabbed Story Map with a interactive builder interface (like Map Tour and Map Journal), see https://twitter.com/EsriStoryMaps/status/540358449138114560 and A sneak peek - the new Story Map Series . Check out StoryMaps website Wednesday and you will see the link to the app!
