Hello and thank you in advance.I am still, unfortunately, a little confused on the projection for posting data in Google Earth:I understand that GE and MS apps use a spheroid only model, which is the projection ESRI calls:Geographic Coordinate System, (spheroid-based) "GCS_WGS 1984 Major Auxiliary Sphere" or Projected Coordinate System (World) "WGS_1984_Web_Mercator"Whereas ESRI uses a spheroid or ellipsoid model, which is the projection ESRI calls:Geographic Coordinate System (World) "GCS_WGS_1984" or Projected Coordinate System (World) "WGS_1984_Web_Mercator (Auxiliary Sphere)" The instructions in Technical Article ID: 34749 say when using 9.3 SP1 to use the:Predefined Projected Coordinate System (World) "WGS_1984_Web_Mercator"HERE IS MY PROBLEM:When projecting from NAD83 to Projected WGS_1984_Web_Mercator in the toolbox,there is a message that this is an undefined projection, and I can only do it with a double: NAD_1983_To_WGS_1984_5 AND WGS_1984_Major _Auxiliary_Sphere_To_WGS_1984The same is true (obviously) if I try to project from NAD83 to Geographic GCS_WGS_1984_Major_Auxiliary_SphereIsn't this exactly the same as just going from NAD_1983_To_GCS_WGS_1984, which is the ESRI model,not the Google Earth or MS (Bing) model, right?In the end, projecting to GCS_WGS_1984 is equivalent to projecting to PCS_WGS_1984_Web_Mercator which is equivalent toprojecting to GCS_WGS_1984_Major_Auxiliary_Sphere The only difference is that the denominator of the flattenting ratio for the PCS_WGS_1984_Web_Mercator is infinityinstead of 298.257224. No matter what, the locations lie directly on top of one another and NOT where I cansee them (my well points) on the Google Earth image.So, how do folks line up their very locatlized point locations on a Google Earth visualization for their projects/clients?In addition, using the double transform to get to Projected Coordinate System (World) "WGS_1984_Web_Mercator" yields the same projected or local bounding coordinates as Projected Coordinate System (World) "WGS_1984_Web_Mercator (Auxiliary Sphere)" HOWEVER, Google Earth will not import the file "WGS_1984_Web_Mercator (Auxiliary Sphere)" (says zero features)Why does this happen?HELP!!Nicki Cook
