Hi-
I am using the labeling from this link for my street sweeping application and the date is incorrect
Create Map - My Government Services | ArcGIS for Local Government
It is returning the same for routes with different sweep days. Example, sweep day for route 12 is Friday, but is returning a date of 3/25 and route 7 has a sweep day of Wednesday, but the expression is returning 3/25 as well.
Thanks!!
The code is below:
/*If the cleaning isn't available year-round
specify the first and last day of the season that cleaning will occur*/
var openSeason = [[1,1],[12,31]]
var cleaningWeek = [];
var cleaningWeekFields = [$feature.WEEKONE, $feature.WEEKTWO,
$feature.WEEKTHREE, $feature.WEEKFOUR]
for (var k in cleaningWeekFields) {
if (cleaningWeekFields<K> == 'Yes') {
cleaningWeek[Count(cleaningWeek)] = k;
if (Count(cleaningWeek) == 0)
return;
function getNextCleaningWeek(fromDate) {
var firstSundayCurrentMonth = Date(Year(fromDate), Month(fromDate), 1);
var firstWeekday = Weekday(firstSundayCurrentMonth);
if (firstWeekday > 0)
firstSundayCurrentMonth = DateAdd(firstSundayCurrentMonth, 7 - firstWeekday, 'days');
for (var k in cleaningWeek) {
var startCleaningWeek = DateAdd(firstSundayCurrentMonth, (cleaningWeek<K>*7), 'days');
if (fromDate <= startCleaningWeek)
return [startCleaningWeek, DateAdd(startCleaningWeek, 6, 'days')];
var firstSundayNextMonth = Date(Year(fromDate), Month(fromDate) + 1, 1);
var firstWeekday = Weekday(firstSundayNextMonth);
firstSundayNextMonth = DateAdd(firstSundayNextMonth, 7 - firstWeekday, 'days');
var startCleaningWeek = DateAdd(firstSundayNextMonth, (7 * cleaningWeek[0]), 'days');
function validateSeasonCleaning(cleaningWeek) {
var startSeasonMonth = openSeason[0][0]-1;
var startSeasonDay = openSeason[0][1];
var endSeasonMonth = openSeason[1][0]-1;
var endSeasonDay = openSeason[1][1];
if (Date(Year(cleaningWeek[1]), startSeasonMonth, startSeasonDay) > Date(Year(cleaningWeek[1]), endSeasonMonth, endSeasonDay)) {
if (cleaningWeek[1] < Date(Year(cleaningWeek[1]), startSeasonMonth, startSeasonDay) && cleaningWeek[1] > Date(Year(cleaningWeek[1]) - 1, endSeasonMonth, endSeasonDay))
cleaningWeek = getNextCleaningWeek(Date(Year(cleaningWeek[1]), startSeasonMonth, startSeasonDay))
else {
if (cleaningWeek[1] < Date(Year(cleaningWeek[1]), startSeasonMonth, startSeasonDay))
cleaningWeek = getNextCleaningWeek(Date(Year(cleaningWeek[1]), startSeasonMonth, startSeasonDay));
else if (cleaningWeek[1] > Date(Year(cleaningWeek[1]), endSeasonMonth, endSeasonDay))
cleaningWeek = getNextCleaningWeek(Date(Year(cleaningWeek[1]) + 1, startSeasonMonth, startSeasonDay));
return cleaningWeek;
var nextCleaning = getNextCleaningWeek(Today());
nextCleaning = validateSeasonCleaning(nextCleaning);
return Text(nextCleaning[0], 'MMMM D, YYYY');<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN></K></K>
