Do the geodatabase need to be SDE (workgroup/enterprise) to be edited via web?
Is it possible to edit file/personal geodatabase over Web?
Do the mxd file (from which the service is created) need to be in the same folder with the geodatabase?
where can i find the *.sd file once the mxd is published?
if we don't go for the "data store" (in case the "feature access" is not selected) then where the data is physically stored when published? in which folder?
Hi Jamal,This problem is the same as the data store problem you identified this this other similar thread,Thread: ArcGIS Server Properties (data store): �??the data item is an inaccessible�?�And Eric addressed it. You need to ensure that the ArcGIS account can access the data location and has permissions on it. In the case of feature services, you'll need to give it read/write access.Registering your data with ArcGIS Server using ArcGIS for DesktopHope this helps,
Hi Jamal,A1. Yes. For web editing, your data must be stored in an ArcSDE geodatabase.A2. No.A3. When you publish a service, the source mxd file need to be accessible to the ArcGIS account. But it does not need to be in the same location as the geodatabase that contains the source data.A4. After you publish a service, its resources are stored in the server directories folders.A5. The same location as A4.Hope this helps,
