I am having issues with building parcel after editing the boundaries. Here are the steps I am using to edit.
What am I missing?
Jonathan,
Without actually seeing the subject features, I would guess there are two possibilities:
1. The edited lines no longer "close" back onto themselves and do not form a closed polygon.
2. The new lines are not associated with the record. You might select the edited lines and assign them to the record. The build process looks only at lines that are associated with the record when attempting to perform the build.
Good luck,
Frank Conkling
Panda Consulting
I am shirking the parcel and not editing the lines. Then trying the build. That eliminates option one as the issues.
According to the demos and documentation, I do not need a plan to edit a parcel. So if number 2 is the issue then there is a bug. I did test selecting the lines and associated with the record and the parcel will still not build.
I just tested the procedure on my data and the lines (and seed) must be associated with the active Record in order to build. If you still experience the issue, you might reach out to tech support.
I finally got the build to work. I manually copied a record GUID into the line features.
Now, I have issues with how this works and the amount of work it will add to a basic edit. Based on what I am reading in the help documentation, I might as well create a record for every edit. If I am making a correction along a plat boundary I will need to build each plan separately.
I am going to search the ideas to see if someone has suggested allowing parcels being build without a record.
Hello Jonathan McDowell, Frank Conkling and Kevin Priestley
The short answer:
Jon - for boundary lines that are associated with different records you should be using this workflow:
But what if all you wanted to do is fix boundary lines WITHOUT creating a parcel lineage? Meaning a 'Quality driven workflow'?
The Shrink to Seed command does shrink the parcel to a seed but currently Build Active and Build Extent will only build a parcel when all the enclosing parcel lines are associated to the same record.
For a 'bounds' land description, by definition, the parcel can be defined by multiple bounding lines, where each could have been defined by a different record.
Bad news: Building parcels from parcels associated to multiple records is currently not supported.
Good news: we have identified this and are planning to enhance the build to explicitly build parcels from closed loops that are associated to multiple records.
Amir
Has this been addressed yet. I am mapping a newly recorded plat and creating a record for said plat. After I have created that record and placed it correctly on my map I select all the surrounding parcels I create seeds for each of those parcels then edit my parcel lines according to the newly recorded plat. I am wanting to do what is shown in this video, https://community.esri.com/t5/arcgis-parcel-fabric-videos/what-s-new-parcel-fabric-arcgis-pro-2-6/td-p/976886, starting around the 38 minute mark. Using the shrink to seed option and a quality driven workflow without those surrounding parcels being attached to the record.
