The Alaska Division of Geological & Geophysical Surveys used LASzip successfully in an interactive map called LiDAR Datasets of Alaska.
I've used LASTOOLs quite a bit and they can be very useful.
Has someone tested this tool?
LASzip | rapidlasso GmbH
Should be quite fast?
Good luck scott, sounds like a lot of work.
Thanks so much for the info guys! Since I've started working with the multipoints which we accquired from a vendor, I've figured out how to bring them into a feature class and convert them to a raster dataset, then bring the raster images into global mapper and export them out to a DEM file. Which is what I was trying to figure out when I started this thread. But I've also learned how to create las files in Global Mapper and create a terrain dataset from the multipoints.
Thanks for all the help!
Hi Scott,
I hope this helps.
try page 13 below multipoint to terrain
check out this lab our team made to address multipoint in 10.2
A quick how to we made on working with Lidar in ArcGIS
http://www.esri.com/~/media/files/pdfs/library/workshops/arcgis102-lidar-workshop.pdf
Good luck,
Steve
Gordon, this topic got remade after the transfer to GeoNET, and was answered on this thread
Would like to get rasters into a USGS .dem file.
Thanks for the extra info though!
Scott,
take a look at the lidar white paper from Esri. It predates the las data set but covers your questions about multipoints to terrain.
http://www.esri.com/library/whitepapers/pdfs/lidar-analysis-forestry-10.pdf
hope this helps
Gordon
I'm terribly sorry, I didn't realize my hyperlink didn't post last time.
Raster to DEM
USGSDEM -- USGS ASCII DEM (and CDED)
