While trying to publish a tile cache REST service from a map package, I am receiving this error.
Does anyone have any tips on troubleshooting this?
Thanks in advance!
I'm getting this message as well. I'm attempting to publish a weblayer to enterprise. I exported to PNG from EGDB and then tried publishing the PNG file. The work around worked for two other raster datasets but I'm encountering the issue with a raster that is 14.5GB when exported out of EGDB to png format.
Hello, same problem here.
Putting the data to a registered folder didn't help.
Neither restart of the publishing service or the whole server.
What does this error really means?
Thanks!
Appreciated Tess – will give this a shot and see how that goes.
regards,
I ended up making sure all data the map document was using was located in a file geodatabase (in a subfolder for organizational purposes) in a registered folder on the hosting server. I did end up manually grabbing the file geodatabase out of the original map package folder and placing it in the registered folder.
There may be a more straightforward way to handle this issue, but it seemed to work fine for me. Best of luck!
Tess
Hi Tess,
I have a similar issue on this - did you ever get a solution ?
Regards,
