If you have trouble, paste Dale's link into a browser.
To piggy-back on this question, does anyone know where to find the list of wkid to latestWkid mappings?
I've asked a dev to create the list. It isn't in the doc (note to self: add enhancement request). I'll post the list here later today.
UPDATE: File is attached. This is valid through 10.4.0. Structure is:
object type: original WKID [authority] -> new/latest WKID [authority] Name
You'll see changes EPSG-EPSG, Esri-EPSG, EPSG-Esri
Example:
pcs: 102100 [Esri:] -> 3857 [EPSG:] WGS_1984_Web_Mercator_Auxiliary_Sphere
It also includes all objects types, including units, spheroids, etc.
pcs: projected coordinate system
vcs: vertical coordinate system
gcs: geographic coordinate system
gtf: geographic transformation
dat: datum
vdt: vertical datum
lin: linear unit
sph: spheroid
vtf: vertical transformation
Melita
Thank you Melita!
Thanks! Once it is published online, will you post a link to the page?
ArcGIS Pro link:
https://pro.arcgis.com/en/pro-app/arcpy/classes/pdf/projected_coordinate_systems.pdf
