Hi
Looking for some advice. I have a Portal for ArcGIS server on Azure and have federated ArcGIS Server on Azure. We had to federate to easily enable the SAML authentication process.
This all works as required however we have one configuration setup we would prefer to have on the ArcGIS Server side. When users upload a map service, we would prefer to keep the datasets as a registered database connection and not the data copy to a hosted database.
Essentially we still want to keep it as it was if the server was not federated. I have previously performed this on a stand alone setup for ArcGIS Server where i set the blockdatacopy option on. The documentation suggests not doing this if we are using portal as a hosted server and while we are for the SAML/uploading option to to upload to my hosted service we would like to keep the connections as they are in the mxd.
Setting up a connection to the ArcGIS server as a ArcGIS Service does not work using the SAML users, only the local setup admin so this option is out for now as it would require two different usernames/password
Anyone set it up like this before?
