I have Map Service with Feature Service capability which has Ownership-based access turned on. I use REST Export map on Map Server of that service. The filtering for logged user works fine - the exported image does not contain the data, that was not created by the logged user. The problem came when I set the layerDefs parameter to any value - in that case, the returned image is blank. I tried different queries, also this one: {"0":"1=1","1":"1=1","2":"1=1"}
If the service does not use Ownership-based access, my queries works with no problems.
Layers in the service are all SDE Feature Classes with Editor tracking turned on.
Is that a bug? Does anyone has the same issue?
Thanks. Filip
Anyone has an answer? The Server version is 10.3.
