Should maybe open a new thread, but the question is very closely related.
I have a folder with a CSV file that was 'found' by GeoEvent when it was first created, which created the GeoEvent Definitions. I have a python script that is updating the CSV on a regular basis (15 minute intervals), but the updated file is not discovered by GeoEvent. I tried to rectify this by setting GeoEvent to delete the input after a successful read, but the file is not deleted. Any ideas?
UPDATE: I also just added two lines in my python script to delete the file after a 5 second delay, but GeoEvent is not 'discovering' the creation of the new file either.
Brian,
As RJ stated above regarding Watch a folder for new .csv files Input:
"Please keep in mind that a known limitation of this Input is that once it has read data from a particular file, it will not re-read that file - even if the file's contents are changed. Deleting and dragging a new copy of the file into the folder being watched has no effect. The Input is remembering the file name and will not re-read the file to re-ingest its event data. You must stop/restart the Input in order to re-read the file, or change the file's name."
Edit: 23-Jan-2018
Behavior for the ‘Watch a Folder for New CSV Files’ inbound connector was changed at 10.5.1 to no longer require that a file’s name be changed for the input to consider it a new file. The mechanism watching the folder for new files still does not consider file properties such as changes to a file’s “last updated” timestamp or file size. However, if you want an input to re-read files you’ve placed in a folder, you can simply stop and restart your input connector and each file’s content will re-read with its content processed as newly received event records.
Your python script needs to output an additional file into that folder, rather than update the existing file. Also, from RJ's response, you cant just add the same file back into the folder.
I would add some type of lookup in your python script to search the folder for the last filename, add a "_n" at the end of the new filename. If _1 exists, grab the integer and +1. For example your original file is "original.json", after your script runs it outputs an update to "original_1.json", next iteration would be "original_2.json". This would ensure the new file would get picked up by that type of input.
~Alex
Alexander_Brown-esristaff Thanks for pointing out that part of RJ's reply... definitely missed it.
Thanks for the idea/suggestion of creating a unique name on the file using the python script. My solution was to return a datetime.now and append that on to the end of the filename. I also kept the delete line in there so that I don't amass hundreds of old CSV files. It's working well though, thanks for the idea.
I have the similar question:
I create an input "Watch a folder for new .csv files" connector.
than an output "Update a Feature"
and use a service to connect two of them.
In my monitor page I can see the input part is increasing
However, the service part and the output part remain 0
service
input
output
I have try to restart all of the input and output but still not working.
I think that in the input number is increasing means that my data can be read by geoevent right?
But how come the service not working?
Where do I miss??
kevinliu
Add a screen shot of PTXTest, it is hard to provide an answer without knowing what the service looks like. Do you have a Field Mapper to 'join' the input to the output? The input is being read, but for whatever reason, your logic in the service is not getting to the output.
Oh I'm sorry.
here is the screen shot:
and the mapper is like this
here are input and output
I have tried with or without field mapper, I can't get the data in both situation.
Hi Guys,
I got the same issue, I still haven't got the input count even I change file name, add inside again.
I found an error in the log through.
Below is the error message, have any idea what are those?
Best Regards,
Than
@Han-WenLIU @BrianBaldwin
I am also having a similar issue. Were you able to find a solution to it.
@wizgis - This was years ago - but I vaguely remember inserting a 'date-time' at the end of my CSV file name when I was generating the files. That way - GeoEvent saw the CSV as a new file - even if after parsing, some of the records had not changed or updated, but it worked to ensure GeoEvent saw it as a new file each time.
