Hello, I am trying to merge multiple .tif aerials into a single source using the Mosaic to New Raster tool. However, I keep getting a blank output. Any ideas or suggestions to have them fuse together into one single aerial? Thanks George
I was trying to merge 37 4-band tif files into one singular .tif file as an 8-bit signed pixel depth character. I am wondering if that was too big and the tool was unable to process it right.
George, this sounds pretty frustrating and maybe you might be on to something regarding it being too big. How big are we talking (in terms of GBs)?
Have you tried doing this in chunks and then merging the chunks? Like maybe the top fourth, second fourth, third one, and then last one? Also, the obvious question here are, are they all in the same coordinate system (and has that been set properly)?
yes they all in the same coordinate system . Maybe i have too many files and it overwhelms it. Also, i tried doing it in chunks which did output a file of them (2) merged together.
thanks GJ
Another workflow to consider is a Mosaic Dataset - Mosaic datasets | ArcGIS Pro documentation. The benefit of this workflow is you're not creating GB's of new imagery on your disk drive, it handles different bit depths, different coordinate systems and such.
Try building footprints? "Build Footprints (found in the Data Management toolbox under the Mosaic Dataset toolset in ArcGIS Pro may solve your issue.
