The error starts coming abruptly and disappears without any action. While it exists, the performance degrades with following error in the error log:
SEVERE
Oct 5, 2026, 11:21:01 AM
Error exporting map Error handling service request :GISService not instantiated and set in the thread local storage.
Rest
Oct 5, 2026, 11:20:59 AM
Oct 5, 2026, 11:20:57 AM
Error getting dynamic layers legend resource Error handling service request :GISService not instantiated and set in the thread local storage.
Oct 5, 2026, 11:20:56 AM
Oct 5, 2026, 11:20:55 AM
Oct 5, 2026, 11:20:54 AM
Error performing query operation Error handling service request :GISService not instantiated and set in the thread local storage.
Hi @Abhi0829,
Hello @JakeSkinner 1. There is total 8 Server machines
2. The privilege and permissions have been reverified and validated.
3. 90 percent of the services are on Dedicated and rest of them are on Shared, which are infrequently used.
Is that 8 ArcGIS Server machines, or 8 machines that compose your Enterprise?
How many services do you have running in your ArcGIS Server instance?
Hi all, We are also facing the same issue and we have a total of 1300 services in a high available arcgis server environment (2 servers) The issue started to appear after upgrading to 12.1 java.lang.RuntimeException ↓ java.util.concurrent.ExecutionException ↓ java.lang.RuntimeException ↓ GISService not instantiated and set in the thread local storage We have increased the number of threads(webServerMaxRequestThreads) in tomcat as we have reached the limit with the default 150 and then we increased the ram and the cpu capacity but still having this issue //Thanks
I'm facing the same issues with high demand layers and nothing Esri Support has provided has made a difference. I changed instance #, looked at heap size, read all the logs. Restarting the services is a temp fix. It was never this bad until my Enterprise upgrade from 11.2 to 11.5
