I have several clients that have used federated ArcGIS Servers since 10.7.1. Their primary publishing media has been file geodatabases rather than enterprise. This has given them a lot of flexibility and some good performance.
For years, there has been a folder "D:\Data" which has been accessible to the team for publishing and updating data. It's an established workflow. ArcGIS Server has 'read-only' permissions onto that folder. Therefore, it has never been able to establish a file lock on the file geodatabase contents. This has allowed the file geodatabase to be updated each evening (assuming no schema changes) and then data would be available the next day.
This was a methodology that was presented back in an official Esri Developer Summit track in about 2018/2019, related to civil defence updates across distribute servers.
As mentioned, the methodology has been well documented and controlled with several clients since 2020/2021. But now, as 12.1 is being rolled out they are unable to complete the workflow.
We're not sure how, as permissions are not there, but ArcGIS Server is now creating locks and preventing the file geodatabase from being update overnight. This is forcing the clients to 'stop' the ArcGIS Server service, update all file geodatabases, and then restart ArcGIS Server.
The above workaround is working for now, but isn't ideal for the clients in question.
Is anyone aware of a suitable workaround or do they know why this 'feature' has been introduced?
