Hi all!
I'm working with a larger DEM raster, and attempting to create a hillshade layer using the system raster functions Hillshade. It runs successfully, and from a zoomed out view, the hillshade seems to look correct.
However, upon zooming in, the layer begins to look more like a contour map:
How I had the tool set up when running the function:
General:
Output Pixel Type - changed to 32 bit unsigned to match DEM layer
Parameters:
Hillshade Type - Traditional
The original layer is already in UTM, and the units are in meters. Unfortunately, I don't have an option to create a mosaic dataset as that's what's not wanted for this particular data.
Is there any ideas as to what's causing this?
Thanks!
