Hi all,
I'm trying to run an ArcGIS Notebook automatically when a Survey123 survey is submitted, and I'd like to confirm my understanding of the options. What I think I know is that there are two different webhooks that could potentially work for this:
- Feature service webhooks - it is possible to create the webhook on the "create" event of the feature service behind the form. The issue is that the feature service triggering the webhook can't be sync enabled. To me this means that if you want to submit a survey using the survey123 app on the phone this won't work. The only way to use the app is to download the survey - i.e. have sync enabled…
- Survey123 webhooks - this webhook is triggered by the form itself. I see there is a way to create these inside of S123 website. However there doesn't seem to be a way to tie a secret to this webhook type would then make it able to trigger a webhook receiver (i.e. the thing that would make the notebook run). So this doesn't seem to be an option either.
From my research and discussion with the ESRI AI support bot, it appears the only actual option in this case is to use either a custom connector that links the webhook to the webhook receiver or to use a 3rd party tool like Power Automate or Make. Is this really the only way to make this happen?
