We are testing an ArcGIS Enterprise Oriented Imagery Layer containing 360° panorama images stored in SharePoint Online.
We observe the following behavior:
- SharePoint-hosted panorama images display correctly in ArcGIS Map Viewer popups.
- SharePoint-hosted panorama images display correctly in ArcGIS Experience Builder Image widgets.
- The same image can be downloaded from SharePoint and opened successfully as a 360° panorama in Marzipano.
- Oriented Imagery Viewer works correctly with Bynder-hosted images.
- Oriented Imagery Viewer does not work with the same image when the Image Path points to SharePoint Online.
Browser developer tools show:
Access to fetch at 'https://xyz.sharepoint.com/...'
from origin 'https://arcgisportal.cloud.xyz.be'
has been blocked by CORS policy:
No 'Access-Control-Allow-Origin' header is present on the requested resource.
We also observed the following errors:
Error occurred while loading the image. Unable to load https://…..
Viewer currently does not support visualizing 360-degree imagery.
Error occurred while loading the image. Cannot read properties of null (reading '1')
Suggest:
- The image itself is valid.
- The panorama format is valid.
- SharePoint image URLs work in Map Viewer and Experience Builder.
- The issue appears specific to Oriented Imagery Viewer loading SharePoint-hosted images.
Questions:
- Is SharePoint Online officially supported as an Image Path source for Oriented Imagery?
- Does Oriented Imagery Viewer retrieve images differently from Map Viewer popups and Experience Builder Image widgets?
- Are there known SharePoint authentication, proxy, or CORS limitations?
- Is a specific SharePoint URL format required for Oriented Imagery?
- Are additional panorama metadata requirements needed for 360° image recognition?
